Hi there,
I'm currently playing around with using LiDAR data to generate high-quality terrains in Houdini and ran into a roadblock. I have these 'voids' or 'holes' in my point cloud that are not filled by the Particle Fluid Surface I'm using to generate the mesh.
Later, when projecting this mesh onto a Heightfield Project, these holes become an artifact as seen in the image.
I also tried a VDB From Particles route, by ended up with the same issue.
I've been trying lately with little success to isolate/mask these holes to scatter additional points in them, but I'm not sure if it's a good strategy.
Any suggestions would be highly appreciated.
Fix Holes in LiDAR Point Cloud
1087 3 2-
- kyozon
- olivierth
- 1184 posts
Either you fix the holes before the projection or you project differently. I currently don't have the time to create an example but here's how I used to do it:
1. use polyfil with Patch Group active
2. use split with that group
3. delete any patch pointing downward
4. Merge and fuse
The other methode is to project with a Volume Wrangle. You use the intersect function and for any voxel that doesnt hit anything (primhit == -1), you use the xyzdist function and primuv function to get the nearest position.
-Olivier
4. Merge and fuse
-Olivier
Edited by olivierth - April 29, 2025 15:19:43
- Tanto
- 545 posts
- johnmather
- 658 posts
