dy Install Libs is a Houdini shelf toolset designed to make installing libraries smooth and simple. No manual edits, no broken installs.
What’s Inside:
- Library from JSON: Import a downloaded library using its JSON file—automatically copies and updates the package file in your library folder.
- Install Library: Generate a new JSON package from scratch, tied to your library folder.
- Library from GitHub: Clone and install libraries straight from a GitHub URL.
- Create Library: Build a library scaffold with templates and auto-generate the package file.
- Restart Houdini: Reload everything easily with one click.
You can get it here: Gumroad [cdordelly.gumroad.com]
Check the Product Website [cdordelly.notion.site]
This may not work for installing render engines, as they typically need a custom .json package file to set up environment variables and paths.
✅ Why You'll Love It:
- Save time – eliminate manual file edits and avoid broken setups.
- Stay organized – manage local and GitHub libraries seamlessly.
🌟 Get It Free!
Download this tool at no cost. If this product makes your work easier, your support is greatly appreciated ♥
dy Install Libs
1156 1 1-
- cdordelly
- 207 posts
Edited by cdordelly - July 7, 2025 18:52:37
- cdordelly
- 207 posts
Hey guys! I want to share a new release from dy Install Libs 1.1
Now you will be able to install GitHub Repositories Releases very easily! It simplifies library installation with just a few clicks, making it ideal for installing multiple libraries.
You can download it here: https://cdordelly.gumroad.com/l/dy_install_libs [cdordelly.gumroad.com]
v1.1 (2025.8.5):
Hope it saves you time! Enjoy!
v1.1 (2025.8.5):
- Library from GitHub: Support for download GitHub Repository Releases.
- Library from GitHub: fixed and replaced old "path" JSON variable for "hpath" where a GitHub repo doesn't have a package file.
- Installed Package File: Support for relative paths using $HOUDINI_PACKAGE_PATH variable.
