Possible to edit multiple objects at same time?
69900 31 10-
- julca
- 274 posts
- toonafish
- 583 posts
- toonafish
- 583 posts
- OdFotan
- 192 posts
peteski
I get that it's probably a deceivingly tricky thing to achieve due to the nature of Houdini but, maybe they could do it by allowing you to multi select a few edit nodes and edit them at once?
Agree,
If you can select a node and edit it, you should be able to select multple nodes, have multiple handles shown and edit them as if you did sequentially select and edit them.
That it keeps track of which handle belongs to which node,
the thing that would make it complicated is that the Edit SOP is not edited by the Handle Tool (Enter), but the select tool, so maybe make the select tool work as an ‘extension’ of the handle tool for nodes that require the select tool as their main feature.. in this way the select tool becomes an kind of handle?
just some thoughts
Edited by OdFotan - May 20, 2020 06:03:09
- anon_user_89151269
- 1755 posts
I'm suspecting that this is a tricky thing to implement because one can't dive in at SOP lvl for multiple objs at once, currently. And this is what's actually required in order to edit two or more objs at once, essentially.
It may be the case that a fundamental change in the way Houdini works, has to be made in order to have this feature, hence its absence thus far.
Hopefully a dev will join this thread and clarify this for us.
Edited by anon_user_89151269 - May 21, 2020 10:26:10
- peteski
- 542 posts
You can actually edit multiple sop nodes at once but it's something that is particularly easy. No idea why because it's really handy.
Here's my toolbar for that in case anyone is interested -
#Get all nodes under the current selection ChildSOPs = [] for node in hou.selectedNodes(): for child in node.allSubChildren(): ChildSOPs.append(child) #Make a list of unique types seen = set() UniqueSOPs = [] UniqueSOPsSorted = [] for SOP in ChildSOPs: if SOP.type().name() not in seen: UniqueSOPs.append(str(SOP.type().name())) seen.add(SOP.type().name()) #Added this to allow Object Level nodes to be selected SelectedNodes = [] for node in hou.selectedNodes(): SelectedNodes.append(node) if node.type().name() not in seen: UniqueSOPs.append(str(node.type().name())) seen.add(node.type().name()) #Choose the node type you want to edit UniqueSOPsSorted = sorted(UniqueSOPs,key=str.lower) input = hou.ui.selectFromList(UniqueSOPsSorted, message="Select Node Type!") if (len(input) == 0): print "Cancelled" else: #Multi Select the nodes! for SOP in ChildSOPs: if (UniqueSOPsSorted[input[0]] == SOP.type().name()): SOP.setSelected(True,False) for OBJ in SelectedNodes: if (UniqueSOPsSorted[input[0]] == OBJ.type().name()): OBJ.setSelected(True,False)
Edited by peteski - July 2, 2020 03:00:50
- OdFotan
- 192 posts
Thanks for sharing,
I worked on some code the last days to adres my specific problem. (mentioned in the link beneath)
I used viewer states and node event callbacks, if anyone is interested:
https://forums.odforce.net/topic/45970-edit-multiple-geo [forums.odforce.net]’sedit-sops-of-a-network-at-the-same-time
Edited by OdFotan - May 30, 2020 21:14:41
- peteski
- 542 posts
- Kirill Tiufyakov
OdFotanThis is very handy and interesting! But it not work in 19.5 python 3.9. If you have time, can you adopt it to the new python please.
Thanks for sharing,
I used viewer states and node event callbacks, if anyone is interested:Image Not Found
Edited by Kirill Tiufyakov - May 26, 2023 16:03:44
- toonafish
- 583 posts
- Tser
- 91 posts
I don't know if this is the same thing, but if you create a Geo object, dive in and add an object_merge, use it to add all the objects you want to modify all at once, select "Transform:Into This Object", now make the original objects invisible by turning off their display flags, now you can modify all the objects points/faces/edges into whatever shape you like, you can even transform the original hidden objects which translates to the Geo objects.
Edited by Tser - Dec. 14, 2025 21:53:20
- Tser
- 91 posts
