Possible to edit multiple objects at same time?
   70070   31   10
Just in case, you can set Network View to Treeview mode and multiselect.
Edited by julca - Jan. 14, 2020 08:20:40
Thanks, but it looks that's only a cosmetic solution.
Then I still have to use the dropdown menu to navigate between Materials, Objects, output etc.
Just in case someone else runs into this Tree View thing.
The “following selection” was the culprit. I did not notice it, and it's disabled by default.
Strangely enough this button doesn't seem to have any effect in the Network View.
peteski
I get that it's probably a deceivingly tricky thing to achieve due to the nature of Houdini but, maybe they could do it by allowing you to multi select a few edit nodes and edit them at once?
Agree,
If you can select a node and edit it, you should be able to select multple nodes, have multiple handles shown and edit them as if you did sequentially select and edit them.
That it keeps track of which handle belongs to which node,
the thing that would make it complicated is that the Edit SOP is not edited by the Handle Tool (Enter), but the select tool, so maybe make the select tool work as an ‘extension’ of the handle tool for nodes that require the select tool as their main feature.. in this way the select tool becomes an kind of handle?
just some thoughts
Edited by OdFotan - May 20, 2020 06:03:09
I'm suspecting that this is a tricky thing to implement because one can't dive in at SOP lvl for multiple objs at once, currently. And this is what's actually required in order to edit two or more objs at once, essentially.
It may be the case that a fundamental change in the way Houdini works, has to be made in order to have this feature, hence its absence thus far.
Hopefully a dev will join this thread and clarify this for us.
Edited by anon_user_89151269 - May 21, 2020 10:26:10
You can actually edit multiple sop nodes at once but it's something that is particularly easy. No idea why because it's really handy.
Here's my toolbar for that in case anyone is interested -
#Get all nodes under the current selection
ChildSOPs = []
for node in hou.selectedNodes():
    for child in node.allSubChildren():
        ChildSOPs.append(child)
#Make a list of unique types
seen = set()
UniqueSOPs = []
UniqueSOPsSorted = []
for SOP in ChildSOPs:
    if SOP.type().name() not in seen:
        UniqueSOPs.append(str(SOP.type().name()))
        seen.add(SOP.type().name())
#Added this to allow Object Level nodes to be selected
SelectedNodes = []
    SelectedNodes.append(node)
    if node.type().name() not in seen:
        UniqueSOPs.append(str(node.type().name()))
        seen.add(node.type().name())
#Choose the node type you want to edit
UniqueSOPsSorted = sorted(UniqueSOPs,key=str.lower)
input = hou.ui.selectFromList(UniqueSOPsSorted, message="Select Node Type!")
if (len(input) == 0):
    print "Cancelled"
else:
    #Multi Select the nodes!
        if (UniqueSOPsSorted[input[0]] == SOP.type().name()):
            SOP.setSelected(True,False)
    for OBJ in SelectedNodes:
        if (UniqueSOPsSorted[input[0]] == OBJ.type().name()):
            OBJ.setSelected(True,False)
Edited by peteski - July 2, 2020 03:00:50
May-22-2020 09-00-00.gif (4.4 MB)
Thanks for sharing,
I worked on some code the last days to adres my specific problem. (mentioned in the link beneath)
I used viewer states and node event callbacks, if anyone is interested:
https://forums.odforce.net/topic/45970-edit-multiple-geo [forums.odforce.net]’sedit-sops-of-a-network-at-the-same-time
Edited by OdFotan - May 30, 2020 21:14:41
selectable_motionpath.share.hipnc (116.5 KB)
Oh wow that's awesome!
OdFotan
Thanks for sharing,
This is very handy and interesting! But it not work in 19.5 python 3.9. If you have time, can you adopt it to the new python please.
Edited by Kirill Tiufyakov - May 26, 2023 16:03:44
Bump !!
More then 10 years later Houdini 21, and still it's not possible to edit multiple SOP's simultaneously.
Time for some AI to step in I guess :-)
I don't know if this is the same thing, but if you create a Geo object, dive in and add an object_merge, use it to add all the objects you want to modify all at once, select "Transform:Into This Object", now make the original objects invisible by turning off their display flags, now you can modify all the objects points/faces/edges into whatever shape you like, you can even transform the original hidden objects which translates to the Geo objects.
Edited by Tser - Dec. 14, 2025 21:53:20
You can also lock the object_merge so it's not connected to the original objects and delete the original objects so you only have the one object if you don't need the original objects any more.
