Retarget apex blendshapes from animated skeleton
3784 16 6-
- alexandrkchaika
Hello everyone,
I'm looking for the best workflow to retarget blendshape animation from an original animated skeleton to the sliders on a new Apex rig.
My source skeleton has animated attributes that drive the blendshapes. My new Apex rig has corresponding blendshape sliders created by the auto-rig tool. I want to use the animation from the source skeleton to drive these sliders procedurally.
I've been exploring how to connect them, but I'm not sure of the standard approach. Is there a way to drive these abstract slider controls from skeleton attributes?
As an alternative, I was wondering if it's possible to procedurally generate or modify an Apex .clip file with this animation data. Could a script be used to write the skeleton's animation into a clip that I can then apply to the rig?
Any advice or examples on how to achieve this would be a great help.
Thanks in advance!
Thanks in advance!
- edward
- 8126 posts
- luoqiulin
- 326 posts
- coonerdltd
- edward
- 8126 posts
Here's the code. But you need to make sure you customize this for your FBX file and rig so that the names match. Also, if you have too old a Houdini version, you might not even have the "fbx_custom_attributes" geometry attribute when you import.
node = hou.pwd() geo = node.geometry() old_attrib_name = "fbx_custom_attributes" new_attrib_name = "parms" old_attrib = geo.findPointAttrib("fbx_custom_attributes") old_dict = geo.points()[0].attribValue(old_attrib) new_attrib = geo.addAttrib(hou.attribType.Global, "parms", {}) geo.setGlobalAttribValue(new_attrib, old_dict)
- 9572 posts
in case your parms are on point 0 as suggested in the above code you can also use
Attribute Promote SOP
- Original Class: Point
- New Class: Detail
- Promotion Method: First Match
- Original Name: fbx_custom_attributes
- New Name: Parms
then you can append Attribute Adjust Dictionary and its Rename Keys multiparm to adjust your mapping, you can also use wildcards when renaming
e.g. (again using above example)
to: CTRL_*_brow_down_start_x
etc...
- New Class: Detail
- New Name: Parms
etc...
Edited by tamte - Oct. 14, 2025 16:37:33
CG Supervisor
Framestore, NY
CG Supervisor
Framestore, NY
- Mishazawa
- 12 posts
Hello everyone,
I'm working on a project with MH and trying to do the same as OP.
I used the approach described here, but only for sliders from `fbx_custom_attributes`. I created a JSON file with the mapping I found on GitHub for the Maya plugin.
Attached project with mapping file (drop next to hip file). I tested with 2 MH characters and 2 exported animations (baked to ctrl rig)
My current result looks like this: the facial animation seems correct, but there's no head or neck movement.
Also it is slow as hell.
Edited by Mishazawa - Oct. 17, 2025 15:20:02
- edward
- 8126 posts
- Mishazawa
- 12 posts
- edward
- 8126 posts
- ChristianGoudy
- 3 posts
- ChristianGoudy
- 3 posts
Edward, I am using your MH_example file and im not really sure where the disconnect is happening, I am trying to export my facial Animation from unreal to control rig and plugging it into the fbx animation node, but im getting several more points than the original animation had, which only has one point.
- william_harley
- 132 posts
- ChristianGoudy
- 3 posts
I have reached that step, but my Parms workflow does not seem to translate at all, when i inspect my face fbx, I see the various transforms on points originating at origin, but it has 79 points or so, but when i inspect the face animation from the example file, it only has one point, I am wondering if there are steps between exporting the facial animation and importing it into the houdini project.
- william_harley
- 132 posts
Hi Chistian, have you had a look at the hip file that Edward posted. You have to change the names of some of the parms coming from
UE to make it work in houdini, and we have included that setup in the hip file.
I simply Exported the animation of the face from sequencer and brought that into houdini. It should be the same for all metahumans
Edited by william_harley - Oct. 31, 2025 02:24:10
- RudiNieuwenhuis
- 227 posts
- Mishazawa
- 12 posts
RudiNieuwenhuishttps://dev.epicgames.com/documentation/en-us/metahuman/character-assembler-for-houdini [dev.epicgames.com]
Epic already provided HDAs for this usecase
