I am trying to use the point instancer LOP using the 1st input points I can not find anywhere that shows me the correct way to sort them like when I am using the internal SOP with the name attribute which works fine.
Can someone give me a hint?
Point instancer using 1st points inputs issue
512 7 2-
- mzigaib
- 1059 posts
- mzigaib
- 1059 posts
- Cold maple
- mzigaib
- 1059 posts
- mzigaib
- 1059 posts
What I am trying to figure it out it is a little more complex.
I did try to simplify in my file to illustrate what I am trying to find out:
-I have a RBD sim on SOP level just saving the points for the instance geometry.
-Using the name attribute with a copy to points I am instancing this geometry which is working.
-I am trying to replicate this with the 2 options on Solaris:
What works:
-Using the "internal SOP" option on the target points on the point Instancer LOP and using the name attribute to fetch the pieces with my points from SOP works.
What did not and I am trying to find out why:
-The same thing but trying to use the "1st input points" using the left branch.
I hope that makes sense.
What works:
Edited by mzigaib - July 7, 2026 15:36:10
- Tanto
- 568 posts
- Tanto
- 568 posts
- mzigaib
- 1059 posts
