Point instancer using 1st points inputs issue
   989   7   2
I am trying to use the point instancer LOP using the 1st input points I can not find anywhere that shows me the correct way to sort them like when I am using the internal SOP with the name attribute which works fine.
Can someone give me a hint?
rbds_point_instancer_issue_v01.hiplc (3.8 MB)
https://vimeo.com/user2163076 [vimeo.com]
Let me know if I am not making sense.
I'm not sure if I've understood it correctly. You can give it a try using this file.
solaris_instance.hip (321.7 KB)
I will take a look, thanks!
Summarizing I just want to be able to use the 1st input with points saved as usd the same way I can use the internal SOP because they don't read the attributes the same way.
What I am trying to figure it out it is a little more complex.
I did try to simplify in my file to illustrate what I am trying to find out:
-I have a RBD sim on SOP level just saving the points for the instance geometry.
-Using the name attribute with a copy to points I am instancing this geometry which is working.
-I am trying to replicate this with the 2 options on Solaris:
What works:
-Using the "internal SOP" option on the target points on the point Instancer LOP and using the name attribute to fetch the pieces with my points from SOP works.
What did not and I am trying to find out why:
-The same thing but trying to use the "1st input points" using the left branch.
I hope that makes sense.
Edited by mzigaib - July 7, 2026 15:36:10
point_instacer_issue_v02.hiplc (2.1 MB)
Right now, your name attribute isn't imported, but it's used to create the usd path of your points. In your point sop import, enable "Primitive Definition/Path Attributes" and remove "name" from the list. Also, add it to the "Import Data/Attributes" list.
Also, be sure to check out Houdini RBD Procedural lop.
Yes that was the missing part, not use name attribute on the SOP import to organize the geometry, thanks!
