Hi everyone,
I’m trying to create a moving light strip / chasing or scanning effect in Houdini.
The effect I’m trying to achieve is similar to an LED strip where:
The entire strip remains constantly bright/emissive.
A moving section of light travels along the strip/path.
The moving section has a different color and/or higher emission intensity than the rest of the strip.
The moving section should produce a Glow/Bloom effect.
The bright section continuously moves/chases along the path.
I have been trying to achieve this using an emissive material on a path/strip, along with Glow, and I have set up a different color/emission for the moving section.
However, my current setup is not working as expected, and I’m not seeing the emissive effect in the final render.
I have attached/enclosed my Houdini setup file
I’m specifically sharing the file because I would really appreciate it if someone could look through my existing setup and point out what I have done incorrectly.
What is wrong or missing in my current node setup?
Why is the emissive material not appearing in the render?
Is my moving light mask/attribute being generated correctly?
Is the emission being transferred/applied correctly to the geometry?
Is there an issue with the material, render settings, or Glow/Bloom setup?
If there are mistakes in my current approach, I would really appreciate an explanation of what the mistake is and how I can fix it.
if there is another/better approach that can achieve the same visual result, I would also be very happy to learn about it.
Any help in reviewing the attached file and explaining where I’m going wrong would be greatly appreciated.
Help Needed: Moving Emissive Light Strip / Chasing Effect
859 2 2-
- gregjenings
- 73 posts
- Tanto
- 574 posts
- gregjenings
- 73 posts
