Hey guys!
It’s still really really early in the making, but I wanted to share a little preview to see if this is something that might interest people.
YT video link [youtu.be]
I'm working on a UI inside Houdini that works kind of like Substance Painter, letting you texture without jumping back and forth between SOPs and COPs.
In the video, you can see how it currently looks: you can drag a layer, paint your mask, and instantly see the result, all in one place. There’s still plenty that isn’t integrated yet, but I wanted to get some early feedback and see if this kind of tool would be useful to others.
Would love to hear your thoughts,is this something you’d use in your workflow?
Copernicus Painter – Layer-Based Painting in Houdini
8617 18 9-
- MatijaK
- 78 posts
- MatijaK
- 78 posts
Video [www.youtube.com]
Some new features have been implemented, including tiling, rotating, and offsetting material textures.Now it is possible to reorder layers, and paint masks are treated as sub-layers of texture layers. Opacity and blend modes have also been added, along with visibility toggles for each layer.
Edited by MatijaK - Nov. 12, 2025 00:57:32
- Hip-Freak
- 40 posts
- MatijaK
- 78 posts
Some updates: the possibility to choose the channel and lower its opacity, and to change the blend type; adding multiple masks on each layer; using alpha masks to paint masks (some update problems to fix). A mask called `Mesh Fill` lets you make a mask from connectivity or UV islands(more selection ways in the future), and `smart materials` that, as you can see, can have custom parameters. A `smart material` is a `.cpio` file that stores a copnet/subfolder node with specific outputs (`color`, `metalness`, `normals`, etc.) and, in the future, inputs as well. `Smart alphas` will also be added in the future . Voilà voilà.
Edited by MatijaK - Dec. 1, 2025 15:24:19
- haraldev
- 3 posts
- MatijaK
- 78 posts
haraldev
This is awesome! Do you have a github page for it or anything? I would love to see if I can contribute. I have been looking for a solution for texture painting and I would love it if I could just do it in Houdini. Right now it's the only thing I'm not comfortable doing fully in Houdini.
- haraldev
Thank you
! For now, the plan is to make this a third-party tool that will be available for purchase. Before that, I’d like to release a beta version for anyone who’s interested in trying it for free and providing feedback.Unfortunately, I haven’t had much time toward the end of this year, so I’m aiming to roll out a beta closer to the end of March, if possible. If there’s enough interest, I’d love to turn this into at least a part-time occupation so I can deliver a functional tool that continues to evolve and improve over the coming years.
- cushwa
- 15 posts
- MatijaK
- 78 posts
- haraldev
- 3 posts
- MatijaK
- 78 posts
haraldevI’m making pretty good progress right now. The plan is to focus on the UI so that it’s as artist-friendly as possible. After that, we can implement additional features like yours. I’ll try to share a beta version soon. I’d be interested to see what you’ve got
Any progress on this? I've been working on some techniques for painting with paths if you're interested
- MatijaK
- 78 posts
It's been a while, here's what Copernicus Painter has been up to
A lot has happened since the last update. Here are the most significant improvements:
- Layer reordering: You can now drag and drop layers wherever you want, with a visual indicator showing exactly where the layer will land. Undo/redo works correctly through reorders too.
- UDIM support: The big one. Copernicus Painter now supports UDIM workflows. Geometry gets split per tile automatically, each tile gets its own COP chain, and you can paint across a full UDIM set. On export you can either export per group per tile, or merge all groups sharing the same UDIM space into a single texture per tile, with proper UV coverage masking so groups blend correctly at their boundaries.
- Undo/redo overhaul: This was a long battle. Sliders, opacity, blend modes, channel toggles, mask operations, all now sit correctly on the undo stack. The viewport and layer panel stay in sync through undo/redo.
- Height channel: Added a height/displacement channel with a remap option and a dedicated bake stash path.
- Bake preview: You can now preview baked maps directly in the viewport before committing.
- Fill mode: Paint masks can now be initialized as fill white or fill black on creation.
- Export window: Texture export now happens through a proper export panel with format, resolution, template presets, and per-channel control.
I put together a video painting on a gun with UDIMs, it covers most of the new features and gives a good idea of where the tool is heading.
Edited by MatijaK - March 31, 2026 06:09:13
- Hip-Freak
- 40 posts
- MatijaK
- 78 posts
Hey everyone!
I'm looking for a few people who would be interested in trying out a private beta of Copernicus Painter and sharing some feedback.
If you're interested, feel free to send me a DM! You can also check the Documentation if you are curious right away :) [matijakos.github.io]
- haraldev
- 3 posts
- johancc
- 53 posts
- MatijaK
- 78 posts
About two months ago, I asked if anyone would be interested in trying the beta version of the tool. Two people volunteered, but unfortunately I never received any feedback from them.
Later, I decided to release the early beta publicly on CgLounge https://cglounge.studio/assets/copernicus-painter-early-beta- . While more people downloaded it, I still didn't receive any feedback or bug reports.
Because of the lack of response, I've decided to pause development for now. The project is very time-consuming, and without knowing whether there's enough interest or whether people are actually using it, it's difficult to justify investing more time into it.
If there's genuine interest and users are willing to provide feedback, I may consider continuing development in the future.
Stencils could be a nice addition, the last feature I did that is not yet implemented for the reason listed above is different projections that can be moved like in SP
dicord channel i've created [discord.gg]
johancc
Hey, cool stuff! Do you plan to add stencil painting like SP? Tnks.
Edited by MatijaK - June 5, 2026 03:46:16
- toonafish
- 620 posts
That's a shame, looks like a great tool for texture painting.
I don't do a lot of texturing , but just out of curiosity I installed it and I've been fiddling around , but it seems I can only open the Painter Panel by first opening a Python Panel and then select "Copernicus Painter" from the dropdown menu. And after adjusting the Project Setup settings and initializing a project I don't see any material in the "Materials Library" and every time I click something I get a Console popup.
I copied the complete CopernicusPainter folder into an "Assets" folder on my C drive and adjusted the path in the CopernicusPainter.json file as shown in the Installation Manual.
I checked the Asset Manager and I can see it scans the "../Assets/CopernicusPainter/otls/..." folders.
I'm using Houdini 21.0.7 / Python 3.11 and Vulkan
Is there something I can adjust to get it up and running ?
- MatijaK
- 78 posts
Hey, we can look into it on Discord if that's not the issue, but it sounds like you just need to specify the folders containing your materials in the Settings menu.
The folder should contain subfolders with textures using common names like diffuse, normal, displace, etc. The tool will try to detect which image belongs to which channel and automatically populate the material library.
If you want to use smart materials, you'll need to create those yourself using the MaterialCreatorUI (it might not work perfectly, but it should work). There you can also create material icons and correct the material channels if the automatic channel assignment didn't work properly.
Smart materials are created by making a subnetwork in Copernicus and adding variables to that subnetwork. Those variables can then be adjusted in Copernicus Painter, which is what makes the materials "smart" and customizable. Something like importing a smart material from substance designer into substance painter
I've tried the tool on Houdini 21.0.7 / Python 3.11 on windows so it should work.
- MatijaK
- 78 posts
