Hi everyone...
There's a note on labs quick material that it's going to be removed in H23, and it'll be replaced by COP Preview Material...
What I am trying to do is export my models to GLTF/GIB format to use in other DCC apps as needed, but right now, I have to go through Blender to put them together.
COP Preview Material isn't showing me the textures correctly...quick material is...
I also tried to create a mtlx gltf material and can't seem to get the materials to show up
Can someone direct me the proper way to export so I don't have to use Blender to get what I want?
glb format preferred, but I can also do gltf as well
Export to GLTF, GLB
435 7 1-
- frescalus
- 32 posts
- johanboekhoven
- 16 posts
Hi Neil,
Here's what I did.
In Houdini 22 there's a new option in the gltf loader. You'll find it under "Load", set it to material.
A new "Bake Material" button appears. Set an output matnet and it will bake a Principled Shader or MatX material in the matnet with all shading properties and textures it could map.
That's the principle. Next I created a HDA that does all the automation for me, and called it gltf_material_builder.
One press of the button builds all the materials and populates a Material Node with the material assignments etc. At that point your geometry has a fully principled shader setup and ROP gltf will work with material assignments.
I can't share it unfortunately, but the above should get you on the right track
Here's what I did.
- frescalus
- 32 posts
johanboekhoven
Hi Neil,
Here's what I did.
Hi, thank you!
Here's the scenario...
I created a tree using labs tree generator... and I am wanting to export it.. what is the correct way to do that initial export where I get the textures when I use the gltf rop export before I bring it back in with the loader?
Also, when I switch load to Material, I get an error cannot import material with invalid id 0
Edited by frescalus - Nov. 24, 2026 08:37:04
-----Neil
- johanboekhoven
- 16 posts
Maybe the export from labs tree generator isn't great to begin with. Houdini is not very flexible with malformed data. If you can try to export a gltf, with bin/textures separate it would be easier to see what goes wrong perhaps. Also make sure it does load and the possible missing extensions are handled correctly in the loader.
- frescalus
- 32 posts
johanboekhoven
Ok, so... progress... I was able to create the mtlx gltf materials, and I was able to export them using the rop gltf output node and setting Image Export to Save to External File. It puts the textures in a base directory instead of say, Textures and save it as a .gltf
if I put the extension as a .glb and select Embed in .gltf, it creates a Textures directory, but doesn't put any textures in it, and I get warnings when importing saying cannot use an image embedded in the gltf as file textures. Same thing if the extension was .gtlf
Either way, I have to select Save as External File... and the goal is the embed them like Blender can do...
Once I bake the materials, I tried a 2nd rop, still didn't embed the textures.
-----Neil
- johanboekhoven
- 16 posts
Maybe embed in gltf (the json definition) can only happen with base64 encoded strings in the gltf.
GLB is a binary zip file, that holds the gltf.json, bin (geometry blob) and the textures.
A .gtlf file is a text file, and it can reference textures from a folder, but also from embedded (as base64 encoded strings) data.
Not sure if that's the case here, as I always export GLB's where everything is embedded.
- frescalus
- 32 posts
- johanboekhoven
- 16 posts
