I am getting following info when generating photon map:
mantra: Aborting photon generation due to an extremely low photon storage ratio. Try using a more accurate photon target.
Obviously I can't change a target, what can I do than?
thanks
kuba
low photon storage ratio problem
4575 3 1-
- kuba
- 345 posts
- symek
- 1390 posts
czesc Kubo,
there are number of reasons your photons aren't saved. Bad surface definition, light that is placed too far, obstacles, too less photons emitted for a given scene's units. As you know you can visualize photons. Check what is going on with them. Sometime simply replacing light was helping me in the same problem.
cheers,
sy.
PS
Photons behaviors are now controlled via physical properties of a shader. Not photon shader as before. Maybe there is something wrong with your F variable?
PS2 Have you managed your challenge with attributes remapping? I sent you some tips…
cheers,
sy.
PS
- kuba
- 345 posts
- johner
- 826 posts
There's some discussion of this error and other photon stuff at:
http://forums.odforce.net/index.php?showtopic=6211 [forums.odforce.net]
