$PR bug
   5555   6   2
make a box,
append attributecreate,
set the vaue to $PR,
the attribute will be all zeroes.
v9.1.153, 32bit debian.
Works fine over here.
Make sure you set the “Class” to “Primitive”, as I don't think $PR is available for any other class (which kind'a makes sense actually).
Mario Marengo
Senior Developer at Folks VFX [folksvfx.com] in Toronto, Canada.
yep thanks that works, with attributepromote (to points).
but so does just putting $PR into $CR via point sop,
so I was thinking it should be doable with attributecreate.
-cpb
He's right, $PR does work in the point sop but not the attribCreate… I wish it was a bug, but for some reason I bet they think it's not…
“They” think it's an RFE.
submitted.
In the mean time use $PR when building a vertex attribute then use Attribute Promote to a point class.
Remember that using $PR in this way only “really” makes sense when you have unshared points. No silly cases in to support now. :wink: (The default box test certainly underlines this.)
ops:
thanks Jeff.
