points() expression in copy sop problem
   4829   3   1
Hi all
have a problem here , maybe someone can help
create a grid
attach attribcreate sop (Name = str, Type= STRING, String = A B C)
feed it into the template input of a copy sop (Var 1= a, Param1 = points(“/obj/model/attribcreate1”, $PT, “str”)
In the primary input of the copy sop feed a font sop (Text = `param(a,0)`)
Displaying the copy sop just shows a bunch of zeros
If I put the points() expression directly in the font sop (and replace $PT with 1) it evaluates the correct string and displays it
Has anyone any idea whats wrong in this network :shock:
Thanks in advance
Achim
figured it out
So what was the problem?
Seems like the params in the copy sop wont work with strings, so I just put this in the font sop
`points(“/obj/model/attribcreate1”, param(a,0), “str”) `
and set the copy sop to
(Var 1= a, Param1 =$PT
Works perfectly
