Colapse into subnet
   8566   5   2
Hello all,
in previous versions of Houdini, it was possible to select a group of nodes, and then with alt-right-click or something like that, get a pop-up menu that said: collapse into subnet . I have found that the shortcut (shift-C) still works in 9.5, but I cannot find the menu option. Is there a menu entry for this, if so, where?
Thanks,
Koen
If you right-click on a node, I see it there …
This is the popup I get after selecting 2 sop nodes. It might just be time for me to leave work and find the nearest bar :-)
Koen
koen
Would that be the Menu Bar? :twisted:
We decided to have different menus depending on whether you right click on the network, or on the nodes.
Shift C (Collapse) is in the menu that appears when you right click the network.
Stephen Tucker
VFXTD
That works,
