I have a model that I am trying to export using the Torque Export.
I am getting an error. It is:
Failed to find capture region
It is coming from my deform node and it makes reference to a bone.
It also says to check that the capture region paths are set correctly.
Well, this bone capture region path looks just like the other bones except for its number.
Any ideas how to figure out what is going on?
deform: Failed to find capture region
4781 5 2-
- tpitman
- 82 posts
- old_school
- 2540 posts
- tpitman
- 82 posts
I can't seem to figure out how to work the capture correct. I put it down just above the deform and put the region name of the bone and it stays with the yellow and black box inside of it indicating something is wrong. I have tried placing it right before the deform and also right after the capture weights.
Shouldn't there be a way to fix the problem with the bone region itself? Do you have any idea where this error comes from?
If you could email me at tony at shatalmic dot com I can email you the file. It would be great if you could figure it out and then explain to me what was wrong and how you fixed it. I am new to Houdini and trying to learn so I can figure this out myself in the future.
- tpitman
- 82 posts
- edward
- 8090 posts
- tpitman
- 82 posts
