Deleting 4 or + points polygons
   6112   6   0
I wondered how to blast or at least group polygons with more than 4 points
Thanks in advance,
Julien
Try using the Blast SOP or the Group SOP. Make sure you have your geometry selection set to primitives.
Is this supposed to be a trick question? If so, it helps if you provided geometry and point out which primitives where you cannot do so.
I think I wasn't very clear in my question
Is there some kind of expression I could use to “select” polygons with more than 4 points ? in order to blast them after, without having to select them in the viewport
thanks
I created a Houdini Digital Asset in a hip file to demonstrate it.
See:
http://odforce.net/forum/index.php?s=60582e40e6788d7a45b660374f5c44a6&act=ST&f=19&t=1654 [odforce.net]
Thanks Edward ! That helps a lot !
Julien
Doh. Forget everything I said. Just put down a Group SOP, change the expression to Group by Expression. Now put type this into the Filter Expression: $NVTX > 4.
That's even easier thanks again
