I have an Intel system running RedHat Linux 9.
I installed Houdini Apprentice, and when I try to run Houdini I get the following error:
error while loading shared libraries: libHoudiniDEVICE.so: cannot open shared object file: No such file or directory
This libHoudiniDEVICE.so does exist on the system. It can be found in the dsolib directory under the path where I installed Houdini. I'm not sure why Houdini cannot find the file.
What do I need to do so Houdini can find the needed file and run properly?
Can't run Houdini Apprentice on RedHat 9
6840 9 1-
- tron_thomas
- 3 posts
- Henster
- 196 posts
- stevenong
- 1634 posts
- JColdrick
- 4140 posts
setenv LD_ASSUME_KERNEL 2.4.1
Actually I've found that those redhat 9 posts seemed to have disappeared from here(or at least disappeared from search
). Not sure why…
I heard a rumour this forum is run on a 10 yr old SGI box…let's all chip in for a cheapo fast linux box and tons o' storage gang!
J.C.
). Not sure why…I heard a rumour this forum is run on a 10 yr old SGI box…let's all chip in for a cheapo fast linux box and tons o' storage gang!
J.C.
John Coldrick
- stevenong
- 1634 posts
- tron_thomas
- 3 posts
I tried running the houdini_bash_setup script.
I also set the LD_ASSUME_KERNEL environment variable.
Neither of these had any affect. I still get the error.
I did a search for RH9 in the forums. None of the posts I found reported the kind of error I'm having with Houdini, and I did not find useful information to fix my problem.
Does anyone have any other suggestions?
- Henster
- 196 posts
- JColdrick
- 4140 posts
- ykcosmo
- 288 posts
- tron_thomas
- 3 posts
I'm using Bash. I'm pretty sure I set the environment and exported the variable correctly. I could type “echo $LD_ASSUME_KERNEL” from any shell instance, and it would print the value I set it to in my Bash profile.
Does the variable have to be 2.4.1? I set the variable to the version of the kernel I am using which is 2.4.2.
