Chops troubles.. (remapping channels with a graph/channel)
5337
5
1
Henster
Jan. 21, 2004 11:44 a.m.
I've got a channel in chops ranging from values of 0 to 1. I want to be able to remap these values using another wave in chops.
So one input channel. And one remapping channel (with a spline chop attached for editing).
I've tried all kinds of stuff, including exporting everything to sops (which was messy).
Any ideas would be very appriciated.
I can draw was well see!
Henster
Henster
Jan. 21, 2004 3:03 p.m.
Sorry if anyones started replying. But, I got it working soon after I posted again. Can you delete posts?
Henster
stevenong
Jan. 21, 2004 5:16 p.m.
Hey Henster,
Instead of deleting this post, why not post your solution instead? This is so others will know how to remap channels or curves in the future.
Cheers!
steven
Henster
Jan. 21, 2004 5:25 p.m.
Sure, love to. I started with one input curve(driven from an audio file) and a ‘remapping curve’ which I created from a constant chop followed by an expression chop containing the expression $I followed by a spline chop for editing. I then ran both these into an expression chop containg the expressionic(1,0,$V) I had to add scalars next to the $V and around the whole expression due to (I think) one of the curves being resampled when connected into the chop. Now when I move the spline nodes it effects the audio driven curve. Hope that makes sense!
Henster
deecue
Jan. 21, 2004 10:37 p.m.
Henster: do you think you could post the solution some where if you don't mind (i also understand if you don't want to as well.. :wink: )? I'm just having a hard time following your solution and I'm really interested in how you did this. thanks, dave
Dave Quirus
Henster
Jan. 23, 2004 12:02 p.m.
Hi Deecue,
Sorry about the delay. Had a big deadline.
I made a new hip in illustrate it. Edit the spline1 sop to change th ramp. I think this principle can be applied to a lot more stuff than just colour.
Try changing the botoom left panel to chops after opening. I think the display flag is set…
http://homepage.ntlworld.com/thehenster/Henster/post.hip [
homepage.ntlworld.com ]
cheers
Henster
