How to force Anti aliasing on vops?
   3436   2   1
I took a splatter pattern and used an inverse vop to flip the pattern but the noise became aliased.
Is there something I can feed it through that will smooth out the inverted splatter before it connects to the mix vop? :?
soho vfx
Use a Mix and feed the splatter into the bias of that…then set whatever colours you may want to use in the mix. This lets you invert and fiddle to your heart's content and still maintain the anti-aliasing from the noise generator. Having more than one Mix is good fer yah - puts hair on yer chest.
But if you *really* wanted to, you could use the Complement VOP…
J.C.
John Coldrick
Mix vop worked like a charm…. :wink:
Thanks John!
soho vfx
