can't drag and drop through out houdini
   15890   18   3
i can't seem to drag and drop throughout the houdini interface
when i am in the material pallette i cannot drag and drop from the galleries into the shop context….
i cannot drag and drop materials onto objects…
and i cannot drag and drop parameters into expressions or other channels
something i'm missing here? some environment variable I have to enable?
Nvidia 470 on win 7 64 bit Intel I7
thanks
no one else have this issue?
no drag and drop materials…or anything else?
it's pretty annoying
Yeah I have been having the same issue and I have worked it out in my case.
My setup is 2 Dell 24" on Windows 7 x64 with Houdini 11.0.581:
It only happens when you have 2 monitors and the second monitor has a lager height resolution.. I have also noticed that the startup logo is not centered on my second screen where I mostly use it.
Hope this helps.
~B)
thanks for the tip!! my 2nd monitor was vertical..
wish there is a solution to this problem.
Hey specs, I have the same problem too. If you actually drag your mouse around the window a bit, you should be able to find a spot to drop your asset (ie bottom right of window).
I do not know about dropping materials on objects. I have not tried that. But dragging stuff off galleries to other windows works fine this way
-G
gray0lorin thanks for the solution!
Has anybody found a fix for this in win 7 yet? I've seen a couple posts about this issue, which is happening to me (I have a second (or fourth) monitor turned to portrait mode)
I am trying to drag a node into the python shell, but I can't get it to work, no matter how much I drag it around.
I'm having this same issue. I can't drag or drop in any interface within Houdini. Has anyone figured out a way of fixing this without getting rid of my second monitor?
Hey Jorge, is your second monitor vertical?
-G
Makes Creating OTL's a real pain !
I notice that the problem goes away if I am VPN'ed into the computer. Must be a UI issue with the GL drivers.
any update on this issue? :?
have not seen it since I made my monitors horizontal…. I highly recommend posting a bug if you encounter this with vertical monitors
-G
And this typical solely specializes in determined vital although really easy to help.
On Linux you need to maximize/restore then DnD will start working again. Don't know if that helps on Windows though.
I do wish it'd get fixed, DnD is a major feature
Peter B
Peter Bowmar
____________
I found a solution for vertical 2nd monitor, drag and drop works
switch to single monitor mode >> launch Houdini >> turn on second monitor again
I have this exact same issue, and I have two monitors running at different resolutions.
It's really annoying, especially since I'm trying to learn Houdini now, and sometimes I have no idea if I'm dealing with an actual bug, or if it's an issue of a setting I've overlooked somewhere.
ken748647
This is the solution I'm currently using..
Issue still prsists FYI
Windows 10
Houdini 20.625
When I have dual monitors. I can't drag and drop anything into Houdini. It seems to be some sort of UI bug?
drag and drop in houdini isn't working with two or multi monitors
Edited by andrewmcbrideatl - June 28, 2024 12:32:34
I'm having this issue as well.
