Cut up mesh with a curve and keep it watertight
   1127   4   1
I'm currently working on a sculpture, and I'm wondering if it's possible to cut off part of it, but in such a way, that it would still leave me with a watertight geometry. Ideally, I'd like to cut it up with a curve and I would like to avoid converting the mesh to VDB, because I don't want to lose the details so soon.
Image attachments with the PigHead depict the result that I'm looking for. I have a feeling this is possible, but at this late hour, I can't think of a way of accomplishing this goal, so I'd be grateful if someone could give me a push in the right direction.
Edited by ajz3d - May 30, 2025 17:28:37
maybe boolean shatter is right for you
Absolutely! Thank you, Atitimar.
Why can you cut it with a curve (instead of a plane) though? Boolean shatter scares me sometimes.
Subtract the height of the mesh points from their closest position on the cutting curve:
vector pos = minpos(1, v@P);
f@dist = v@P.y - pos.y;
Then remap the distance as weight to smooth the bottom part with poisson interpolation.
That way the mesh remains intact despite of cutting it.
curve_cut.hip (368.4 KB)
