I may be overthinking this, but I'm working on an HDK plugin that I have a need to internally process batches of points based on the primitive attribute "path".
so, basically work thru all the geometry points like a for-loop sop node functions if you changed the "piece attr" to "path"
I was thinking of creating and destroying groups for each and then looping on each group using GA_FOR_ALL_GROUP_PTOFF
but I feel like that could be pretty slow.
The For-each sop is so fast, there has to be a way to quickly do this, but I'm just not thinking about it correctly.
Thanks in advance.
HDK operate on chunks of points based on "path"
672 3 2-
- redpaw
- 82 posts
- cwhite
- 795 posts
- redpaw
- 82 posts
Thank you!
I figured out what I needed I think.. I got the lookup table of individual "path" prims
Then I had to iterate thru those and get the offsets of the points (basically the vertices) of each prim path.
I could then flatten this list to remove duplicates, and that was the "points" (offset array) I was after.
Then I could just iterate thru that array of point offsets and update my point attributes.
Very much appreciate the point in the right direction!
-johnc
-johnc
- cwhite
- 795 posts
Great!
One other note is that you might be able to use GA_Range to build the point range from the primitive offsets, something like (untested)
GA_Range prim_range(geo.getPrimitiveMap(), prim_offset_list); GA_Range pt_range(geo, prim_range, GA_ATTRIB_POINT, GA_Range::primitiveref(), /*harden*/false); for (GA_Offset ptoff : pt_range) { ... }
