Modify SOP geometry UV from COPs
   78   0   0
Hi all!
I have a quick question - I'm using a slap comp node inside COPs to retrieve a UV Render Var (AOV), which is generated from the camera projection onto the mesh.
I'd like to use this UV to modify the UV attribute from a SOP geometry imported inside that same COPs network, in order to apply a texture within that UV space; anyone would have on idea on how to achieve this?
