generated hair offset when imported into stage
   460   2   2
Not sure if this is 100# Solaris issue but I've just got this weird thing.
Have an carpet model, generated guides and deformation guided by vellum sim.
All looks fine in /obj but as soon as I pull those into /stage groom have a bit of an offset.
Any ideas what is going on? Weird is it was working fine up until one point.. no idea what really changed and there are no transformations on anything 100%
Images fails to load for some reason but anyway, update, if I use Import Scene (All) then both grooms and geometry are perfectly aligned. If I import in separate SOP import there is offset between grooms and mesh..
Do you have an Object-level transform on one but not the other? SOP Import only imports the SOP, not the Object.
If you're still having issues, can you send us a hip file?
