Might be a stupid question, but I'm not sure how groups work
   377   2   0
If I place a group node down, how do I then select the points, primitives or edges I want to be placed into that group?
I know that I can select things in the previous node, then hit tab and select group, but is there not a way to place a group node down and then select faces, etc while within that node?
I ask because it seems like some effects are activated from the viewport, for example, selecting edges and then adding a bevel or extrude to faces, and others are activated through placing a node down and then taking an action.
I feel like I'm missing some basic thing here, or is this just the way that certain nodes function?
There it is.
Thank you
