How to center an object ?
   254   1   0
Hello, I'm new here. I'm looking a fast way to bring my main object (the cup from the tutorial)
to the center. Everything is right into the option however the result isn't right. Is there a short cut like in Blender "Alt+G" ?
I know I could manually bring it to the center, where the sphere is but that isn't really "professional".
1. Check your 'object' transform (translate) is 0, 0, 0. This is the 'folder' in which your geometry exists.
2. At geometry level there is a very useful SOP : 'match size'. See: https://www.sidefx.com/docs/houdini/nodes/sop/matchsize.html [www.sidefx.com]
You may have to use this higher up in your network as I think that cup has a handle that will throw off the 'centring' if you have that created.
Edited by Mike_A - Oct. 22, 2025 18:19:17
