Edit properties node not working with MPlay
   744   0   0
Hi all, I'm having an issue with houdini 21.0.512. If I use the edit properties node to edit a primvar, it renders correctly in the scene view, but looks completely wrong in mplay. I also tested in houdini 20.5 and it works correctly there (scene view and mplay render the same). I've already submitted a bug report about, just posting here in case there was a change in workflow that I wasn't aware of between 20.5 and 21 that I'm not following correctly.
In the attached image I'm using the edit properties node to edit the dirt intensity on the building.
