I have seen a setup of an Attribute Wrangle using this code:
s@myname = prim(1, "path",0);
Where a path attribute from fractured geo is input in to the second input (i.e. 1 in the Wrangle).
But what is the 0 for?
Question on VEX prim function
580 6 1-
- litote
- 275 posts
- EZiniT
- 88 posts
- litote
- 275 posts
- EZiniT
- 88 posts
- Integral3D
- 22 posts
the prim function takes three things, the data stream, aka the input to the wrangle, the attribute (as a string) you want to read, and then the primitive you want to sample that attribute from. So in your case you are looking for the path attribute on prim 0 from the second input of your wrangle. The 0th prim, prim index 0. You could sample the second, third, 583th prim or any primnum. But the 0 means your are sampling prim 0. You can visualise the prim num next to the Velocity and point num etc on the right hand side of the viewport.
As a tip, if your type out the function without closing the brackets, "prim(" and wait a split second, you will get the documentation for VEX functions
Edited by Integral3D - Jan. 23, 2026 04:47:18
- litote
- 275 posts
- BabaJ
- 2176 posts
litote
Thanks everyone. I somehow manage to find the wrong syntax listed for the function on a search, it had things in the wrong order so it didn't make sense. Thanks for confirming this.
You might find the SideFX Vex Functions page usefull in the future:
https://www.sidefx.com/docs/houdini/vex/functions/index.html [www.sidefx.com]
