Arnold does't read second UV (uv2) in MatX, Solaris
   764   1   0
I'm building a MtlX Material to be used "cross-render" in Karma, Arnold and probably any other engine that utilized MaterialX.
Cannot make Arnold to use second uv set (uv2).
I have connected mtlx_geom_prop_value node to texcord in mtlx_image node.
If i type "uv" in Geomprop string then its picking up the first UV, but if i type uv2 it doesn't.
Is it a bug or should i use some different node instead?
Houdini 21.0.631
H2A 6.4.6.0 (Arnold 7.4.5.0)
Screenshot 2026-04-13 15.01.36_result.jpg (101.0 KB)
Screenshot 2026-04-13 15.01.51_result.jpg (90.9 KB)
Screenshot 2026-04-13 15.02.08_result.jpg (101.3 KB)
Oh. I got it working by setting geompropvalue to v3 instead of v2. and then by separating 3 vectors and combining 2.
Edited by iraklisan - April 13, 2026 08:35:21
Screenshot 2026-04-13 15.54.23.png (2.3 MB)
