Viewport Isolator - Am I Doing It Wrong?
   735   2   1
Hi all,
I've got an object and I want it invisible in the Perspective view, but visible in the Front, Top, Left, etc. views.
I'm using the Viewport Isolator node in SOP, however, its not giving me the results I want--the object is invisible in Perspective (as I want), but its invisible in the other views as well. Am I using this wrong?
Screenshot 2026-07-02 094934.png (136.4 KB)
hi go over each view, press D and checkt the "Visible Objects" entry under the Optimize tab. Persp. should be set to * ^/obj/REFERENCEand the others with *.
That worked! Also--I had to uncheck the "Apply Operation To All Split Views" which is at the bottom of the dialog box.
Thanks for your help!
