Undo group problem
   477   0   0
In the shelf tool, throwing an exception does not modify the scene. I want to implement this functionality in the Python panel.
This code works normally.
try:
    with hou.undos.group("my code"):
        hou.node('/obj/geo1').createNode('box')
        raise hou.Error()
except:
        hou.undos.performUndo()
However, if an error occurs before modifying the scene, the current undo group is not recorded in the undo history. The undo executed in the except block will cancel the previous operation.
try:
        raise hou.Error() # raise exception before modifying scene , no undo is added to undo history.
except:
        hou.undos.performUndo() # undo operation before my code
How to solve this problem?
