I am recreating a real-world environment using a heightmap, OSM roads, and LOD2 buildings.
Inside Houdini, everything is perfectly aligned and centered around (0,0,0). The roads are projected onto the terrain via a project node.
In Unreal Engine 5.6, the roads and buildings align perfectly with each other, but the generated Unreal Landscape is completely offset in X/Y/Z.
Setting the HDA Actor to (0,0,0) does not fix the mismatch.
Why does the plugin interpret the terrain pivot and scale differently than the geometry, and how can I enforce a perfect 1:1 alignment?
Specs: Houdini 21 (Indie), Unreal Engine 5.6
Thanks a lot!
HDA Terrain shifted against Geometry (H21, UE 5.6)
582 0 0-
- af2001
- 1 posts
