Karma pyro fire shader.
   191   0   0
Hello Wizards,
I have a quick question regarding the Karma Pyro Fire Shader in Houdini.
I'm using Axiom for the fire simulation, and the fire looks correct when viewed through the Pyro Bake Volume SOP, including the fire color and intensity ramps. However, when I bring the volume into Solaris and render it with Karma, the fire looks significantly different.
Is there something specific that needs to be configured in the Karma Pyro Shader to match the Pyro Bake Volume look? Or are the Pyro Bake Volume fire ramps primarily intended for viewport visualization and therefore don't translate directly to the Karma shader?
Any insight into the correct workflow for matching the Pyro Bake Volume look in Solaris/Karma would be greatly appreciated.
