H22: HDA Help Line Break
474 4 1-
- alexeyvanzhula1984
- 109 posts
- Italimpex Productions
- 32 posts
Hello. That's a v22 bug, it stopped working for me too. Now I'm only able to add one split \n and others are ignored. But it's still possible to trick UI parser in Type Properties window by manually escalating number of spaces that serve as prefix and suffix for each split \n. For example, first split: Second split: Third split: Notice the increasing number of spaces for each split before and after "\n".
Obviously it gets annoying to manually format splits like this so I set up a Python script to automate it. Just create a regular shelf tool, fill in name and label and under Script paste this:
So now you're going to write help description for your parameter in random text editor like Notepad. Then you will format the text by clicking Enter to split sentences as you wish.
For example:
Script will recognize where you pressed Enter and correctly format the paragraph. Also, console will print a message saying formatted text is copied back to clipboard:
Once it's automatically copied to your clipboard you will simply go to your node's Type Properties and paste the clipboard into Help field. Now you can do the same for all other help descriptions. Write the description in notepad, press Enter to format and organize the paragraph as you wish, copy it, then click on the shelf tool which properly adds \n in every place where you pressed "Enter" and copies it back to clipboard, then you can ctrl v that into your parameter's help field.
I hope that helps!
TEST \n TEST
TEST \n TEST
TEST \n TEST
import tkinter as tk def fix_hda_tooltips(): root = tk.Tk() root.withdraw() try: raw_text = root.clipboard_get() except tk.TclError: return lines = [line.strip() for line in raw_text.splitlines() if line.strip()] if not lines: return out = [] for idx, line in enumerate(lines): if idx == 0: out.append(line) else: pad = " " * idx out.append(f" {pad}\\n{pad} {line}") root.clipboard_clear() root.clipboard_append("".join(out)) root.update() root.destroy() print("Formatted text copied back to clipboard!") fix_hda_tooltips()
For example:
Lorem ipsum dolor sit amet, consectetur adipiscing elit. Donec tempus fringilla dolor, ut faucibus erat tempus eu. Duis pharetra iaculis lorem quis fringilla. Curabitur mollis hendrerit mauris, nec gravida tellus. Mauris pharetra augue eros, ac luctus mauris viverra non. Curabitur mollis mollis ante, quis placerat diam laoreet ut. Praesent finibus quam ut ante gravida, nec luctus risus feugiat.
Lorem ipsum dolor sit amet, consectetur adipiscing elit. Donec tempus fringilla dolor, ut faucibus erat tempus eu. \n Duis pharetra iaculis lorem quis fringilla. Curabitur mollis hendrerit mauris, nec gravida tellus. \n Mauris pharetra augue eros, ac luctus mauris viverra non. Curabitur mollis mollis ante, quis placerat diam laoreet ut. \n Praesent finibus quam ut ante gravida, nec luctus risus feugiat.
I hope that helps!
Edited by Italimpex Productions - Sept. 6, 2026 13:56:47
CGI Studio specializing in directing and producing advertisements & films
- 109 posts
- elovikov
- 163 posts
i think h22 switched to wiki markup for tooltips (sidefx flavour of markdown) for better formatting
use <br/> as it inline html by default
you can even use some stuff like
this is obviously not backwards compatible though
*bold* or _italics_, prob not all the features of markdown is supported, but main ones arethis is obviously not backwards compatible though
- 32 posts
elovikovThis works, thanks for pointing it out!
you can even use some stuff like*bold* or _italics_, prob not all the features of markdown is supported, but main ones are
