HDK : Multi output
   168   1   0
Hi everyone. I'm trying to export something from the second output but with no luck.
I found a sample file "SOP_dualStar" that seems to be having what I need but I can't figure out the logic completely.
In a header file we should have
GU_DetailHandle cookMySopOutput(
OP_Context &context,
int outputidx,
SOP_Node *interest
) override;
It also has void buildStar(GU_Detail *dst,
OP_Context &context);
As far as I understand the logic happens inside the
cookMySop that runs "buildStar" logic
But then what is happening in cookMySopOutput ?
GU_DetailHandle result;
GU_Detail *dst = new GU_Detail();
result.allocateAndSet(dst);
buildStar(dst, context);
Is there any chance someone could explain to me how that works ?
I need to do some logic on input geo, create an attribute and write it for the first output, for the second output I want to create some points based on array that has been created when doing logic for the first output.
I kind of made it working at some point but looks like array was empty.
So I made it working. Not sure that is the right way though.
In a header file we declare
GU_DetailHandle cookMySopOutput(OP_Context& context, int outputidx, SOP_Node* interests) override;
Also we declare some struct to use later for the second output
struct point_data
UT_Vector3 pos;
fpreal total_length;
private:
UT_Array<point_data> point_data;
All logic happens in cookMySop and I keep values in point_data variable.
Then in
GU_DetailHandle SOP_groom_segmentation_data::cookMySopOutput(OP_Context& context, int outputidx, SOP_Node* interests)
GU_DetailHandle handle;
if (outputidx == 1)
some logic here where using variable from main cook.
Is it okay to use if (outputidx == 1) ? And is it safe to keep and use point_data variable in this case ? Can someone confirm ?
Is this the legit way of doing it in general ?
