Exporting labs flipbook doesnt work in Houdini 22
   336   0   1
Hello.
Is there a known issue with exporting pyro simulations made in Copernicus using ROP Labs Flipbook textures?
I simulated pyro in Copernicus. Then in geometry context I made it loop and used Pyro Bake Volume as pointer for the Labs Flipbook Textures ROP.
When I render from Labs Flipbook Textures, it starts the process but soon it gives errors and crashes.
The same happens if I try to open the same project in Houdini 21,5 and render from there. It gives errors and crashes.
I can write what the error message says a bit later.
Thanks.
