combining?
   7461   1   1
Hi Everyone. I hope you can help me with this problem i got. I think it is simple but i cant figure it out.
I have made all the panels for a cg terrarium, and they are seperate objects. They are all polys, and i have beveled all the edges. But i dont know what to do from here on, i cant figure out how to sellect points from two seperate objects so i can fuse them.
There are 8 panels total, and think it would be the best to get them together in a good way so i dont get any light leaks. I hope someone can help me.
Thank you all very much. Mark
in the modify shelf there is a tool called “combine” you can use this to bring separate models together.
You could also create a new object, and use an object merge node to bring in all of your objects. Be sure to place a . in the Transform Object parameter on the Object Merge.
Stephen Tucker
VFXTD
