The last time I was on Houdini, it was ver 1, I had be using Prisim, yes that was a long time ago… any whoooo.
I have a sphere that I want to be a wireframe when it renders out,, Im also ani. it with slice.
Other objects I want to render has normal solids, does this all make
sence?, Ive looked at the wireframe SOP, didn't seem to work, Iam using 3DsMax where I click a button. Can any one point me in the right direction?
TIA!
ollie
Wireframe Render on some objects... or the cat gets it.
18530 12 5-
- ollieslats
- 14 posts
- jason_iversen
- 12999 posts
You can try follow the geometry with a Primitive SOP and in the Face/Hull tab, change the “Close U” to “Unroll”. You can also use a Carve SOP.
This will open all your polys.
- ollieslats
- 14 posts
jason_iversen
It worked with the Primitive SOP, didn't try thre carve SOP, next question, how can I tweak the width of the wireframe out of the primitive SOP?
And remember, that cat is sitting right in front of me.
- keyframe
- 1533 posts
- ollieslats
- 14 posts
keyframe
After your primitive sop, append an “Attribcreate” sop.
Name the attribute “width”, and assign a value 0.01 for example.
Best,
Gene
I seem to only have sizes of 1 2 3 or 4????
does the “class” or Type need to be set a certain way??
My tree is ; sphere/primitive/carve/attribcreate
does the sphere is to be a certain type, Im using Poly Mesh/rows and columns.
I really do thanks you guys!
- keyframe
- 1533 posts
- ollieslats
- 14 posts
- keyframe
- 1533 posts
- ollieslats
- 14 posts
- czesiek
- 13 posts
- Allegro
- 696 posts
As a side note: If you do a flipbook, in say, invisible wireframe mode, the resulting render will have an alpha channel arranged in such a way that you could easily take the images into the compositor and have your wireframes and even composite them onto your fully rendered objects.
Stephen Tucker
VFXTD
VFXTD
- digitallysane
- 1192 posts
ollieslatsReset the transforms on the object you put on the path (translates, rotates etc). Also middle click on the object node in the network editor and check for pre-transforms, and reset those from the pre-transforms menu in the parameter pane.
that did the trick, thanks soooo much. Now I've drawn a curve has a path, made a ball, picked the Place on Path… but I should moved it to the front of the path, but it doesn't…. the ball moves like its on the path, but it seem 2 be transformed off away from the path????
any help on this one?
Dragos
- symek
- 1390 posts
czesiek
The idea is:
When you create attribute, you are using small letters
When you make a call for this created attribute in expression you are using Big letters
When you creating new shader or different operator you will again use small letters for calling
This is not correct actually. There is slight but significant difference between attributes and variables. I tried to describe it best I could here:
http://www.sidefx.com/index.php?option=com_forum&Itemid=172&page=viewtopic&t=11090&highlight= [sidefx.com]
(although I feel it still needs some clarification).
