I have messed up a Vex Surface Shader
   4322   2   1
Hi, I'm new here.
I have un-installed the Houdine 6 and installed it again, but it “remember”
my old settings, and errors…
I have manage to messed up the Vex Surface Shader… ops:
It is impossible to remove the network I have made within it.
I have removed everything in the registry with RegCleaner, but no, next time I installed it - wops it is all back.
So to the point: How do I un-install Houdini 6, so it doesn't “know” that it has been on my pc(xp) here before, when I then re-install it :?
Any help?
-StingRay
Hi, it could be something in your Houdini profile. Please check in your own home/profile directory and remove Houdini6 folder.
If you're in Windows machines, they can be found in
CDocuments and Settings/<USERNAME>/local directory/temporary/Houdini6 <– (something like this)
Linux machine can be found in your own home/login directory: ~/Houdini6
Hope that helped.
A.
YES !!!
Thanks! I have now re-installed it, afer I removed the Houdine-folder
throug the path you gave me
Thanks Again!
-StingRay
