Hi there!
I just did a basic setup to model a Tank tread…
I was actually wondering what would be the best way to animate it, make it roll? Anybody can help me?
Here's what I have done yet…
Tank Treads
17084 10 0-
- jrgauthier
- 243 posts
JR Gauthier
Character Animation & Design
www.turboatomic.com
http://www.vimeo.com/user2847970 [vimeo.com]
www.turboatomic.com
- stu
- 252 posts
- jrgauthier
- 243 posts
Sounds interesting Stu,
however if I add a creep Sop right now, I have no clue how to make it work, can you give me more details please?
JR Gauthier
www.turboatomic.com
www.turboatomic.com
- stu
- 252 posts
- jrgauthier
- 243 posts
Thanks man, I didn't see the attached file because I wasn't logged in when I read your post.
ops:
I can't believe how this kind of stuff is simple to do in Houdini! (Once you know how…
It's clear now..I guess!
Thanks again!
ops:I can't believe how this kind of stuff is simple to do in Houdini! (Once you know how…
Thanks again!
JR Gauthier
www.turboatomic.com
www.turboatomic.com
- jrgauthier
- 243 posts
Here's another quick question,
would you know what would be the best way now to make those tread go forward relatively to the tread speed?
JR Gauthier
www.turboatomic.com
www.turboatomic.com
- probbins
- 1145 posts
- jrgauthier
- 243 posts
probbins:
Wow that's really nice man! Thanks
I noticed there are some treads tiles jiggling lightly when they are on contact with the ground, how could we avoid that?
JR Gauthier
www.turboatomic.com
www.turboatomic.com
- probbins
- 1145 posts
hmmm, I haven't noticed that but it's probably due to the way the tread polygon is aligned to the rail.
It's aligned at one end and so the tread maybe flopping at the other end, since the pivot is at the rail.
To fix that would require a bit of trickery on the tread.
You'd convert the tread poly to a nurbs surface, so you can align it in both u and v, then convert it back to polygons after the align and before the extrude.
That way you can align the center of the tread to the rail.
“everything is coincident”
- jrgauthier
- 243 posts
JR Gauthier
www.turboatomic.com
www.turboatomic.com
- simonl
- 33 posts
