Hi
Houdini won't go pass the splash screen after i installed and tested the fur plugins.I have a feeling that the fur plugins messed up my houdini setting but not sure what went wrong.I did the usually uninstalled everything and fresh installed houdini but still doesn't work.any help?
1660: Fatal error: Segmentation Fault
houdini won't start :Segmentation Fault
17121 5 0-
- altbighead
- 113 posts
- stevenong
- 1634 posts
- JColdrick
- 4140 posts
I suspect he's referring to Mark Visser's plugins that were mentioned over on odforce(and they're pretty damned cool). I believe early releases of them were somewhat aggressive about how they installed on Windows and permanently wired some important envars to a specific install of Houdini, the upshot meaning that the moment you upgrade Houdini it doesn't work. You need to delete any HOUDINI_ envars from your setup - I believe HOUDINI_PATH and HOUDINI_DSO_PATH are set. Certainly nothing serious was done, it just seems that way.
I think he tweaked the windows version to stop doing this, alternatively you can simply copy the materials to somewhere in the HOUDINI_PATH like $HOME and it should pick things up automatically.
J.C.
J.C.
John Coldrick
- altbighead
- 113 posts
- altbighead
- 113 posts
- altbighead
- 113 posts
