Sorry… very little VOP editing experience… I'm looking for a pointer (help) on how to add point Alpha recognition to an existing VOP network. I don't see this functionality in any of the shipped VOP materials (9.1.124).
Additionally, is there a way to incorporate “exist” type functionality in a VOP shader without using texture maps? Perhaps using the Alpha value of a point?
Point Alpha in VOP network
4784 5 1-
- fgillis
- 157 posts
- mark
- 2675 posts
fgillis
If you create a float parameter named “Alpha”, the value of the parameter should be picked up if geometry has an attribute named “Alpha” (of the same size). If the geometry doesn't have the attribute, then the default you specify will be used.
You can then take that parameter value and use it however you want (i.e. convert to a vector and send it to Of, don't forget to multiply Cf by the alpha).
As a note, if you make the Alpha parameter a “color”, then you can have an RGB per-point alpha if you choose.
Hope this helps.
- fgillis
- 157 posts
- fgillis
- 157 posts
Why do so many answers lead to new questions?
Here's a simplified example of my new problem…
A scene with dozens of spheres… many of them overlapping. I'm animating the Alpha of each sphere using a random function in a point SOP. Everything works fine and the spheres dissolve on at random times.
The problem is that foreground spheres that have not yet dissolved on are acting like matte objects, cutting away the spheres behind them.
I don't have this problem when using the supplied Super Material shader… only with one of the newer supplied VOP shaders that I modified to recognize point Alpha.
Any additional pointers?
It would be nice to have a VOP example of the Super Material shader.
Thank you.
Thank you.
Floyd Gillis
- mark
- 2675 posts
fgillis
Thank you.
The Of variable will make the spheres opaque. So, you want to plug the Alpha into the Of (as well as scaling the color).
The VEX code should be something like:
surface foo(float Alpha=1)
Cf = Cf * Alpha;
Of = Alpha;
- fgillis
- 157 posts
