Python: Parameter Operation from a Delete node...
   7115   2   0
Dear friends,
I'm trying to set the parameter called “operation” in a “delete” node to “delete non-selected”. I created the node with
mydelete = parent.createNode('delete')
and deleted the file node. Now, I want to set that parameter, but I don't have the faintest idea about what to pass to
mydelete.parm('operation').set(…)
or anything like that!
Thanks in advance!!
froure.-
Menu parms can be set two different ways. Either the index of the choice, or the menu item name.
Also, the parm name is ‘negate’. HOM expects the parm name, as opposed to the label.
mydelete.parm('negate').set(1) will Delete Non-Selected
mydelete.parm('negate').set('keep') will set Delete Non-Selected
To set it back to default,
mydelete.parm('negate').set(0)
mydelete.parm('negate').set('dele')
mydelete.parm('negate').revertToDefaults()
You can also see the menu entry names in the Edit Parameter Interface window, or by looking at ‘menu_items’ in the ParmTemplate:
mydelete.parm('negate').parmTemplate()
Ok! Thanks for all!
I will try it!
