Hi friends!
I need change, for example, the params of DELETE named “Start / End”.
For change a Start parm I use:
myDelete.parm('rangestart').set(1)
but, for change de End parm, I use the same code:
myDelete.parm('rangeend').set(4)
and it doesn't run.
In the Houdini interface, this parm is printed in green, and show “$N”. It is important?
Thanks for all!
Ferran.
Python -> Change parameters in green
5892 2 0-
- froure
- 15 posts
- graham
- 1925 posts
The problem is that the rangeend already has an expression set and you cannot just do a hou.Parm.set() on it. There are two options:
myDelete.parm('rangestart').setExpression('4')
This just sets the expression value from ‘$N’ to ‘4’
or
myDelete.parm('rangestart').deleteAllKeyframes()
myDelete.parm('rangestart').set(4)
This deletes the expression, then sets the value normally. This is my preferred method.
or
- froure
- 15 posts
