NSIS Error Installing Houdini
   11515   10   0
hi…
The following error occurs when installing ''Houdini 9.1.250 Windows 32-bit (VC8)'' :cry:
My web:
www.anim3d.de.tl
www.anim3d.blogspot.com
The expected size and MD5 hash of the installer are available on the download page so you can verify your download if you run into problems.
For the build you downloaded, the size should be 142,393,344 bytes, and its
MD5 hash should be 489670ea8e4782215a7ead1e8edcb111. Do these match what you have?
downloaded over 3 times but I always get the same result
Size: 139,056 bytes (smaller download size)
MD5 hash: 489670ea8e4782215a7ead1e8edcb111
many thanks
My web:
www.anim3d.de.tl
How are you calculating the MD5 hash? It's extremely unlikely that you're getting the same hash with the much smaller download size.
Which browser are you using? Are you using any kind of download accelerator?
Hi benytone,
I just downloaded the file using Firefox 2.0 with the DownloadThemAll download accelerator add-on without problems. md5 checksum matches too.
Either it's your browser or maybe the download accelerator you're using.
Cheers!
steven
I've used Firefox 2 and IE 6 but I'm having no luck, as you can see I get 135 mb!
My web:
www.anim3d.de.tl
Try disabling your antivirus program, also be sure you're not using any acceleration programs at all.
J.C.
John Coldrick
JColdrick
J.C.
But it's still not working!
:cry:
My web:
www.anim3d.de.tl
Then you've got something interfering with your downloads.
J.C.
John Coldrick
Hey benytone,
You can try downloading the file from my server [pointy.tv]. It is 135.80 MB or 139056KB.
If it still doesn't work, maybe it's an update you installed recently?
Good luck!
Cheers!
steven
stevenong
Hey benytone,
Good luck!
Cheers!
steven
Hi stevenong
That's very kind of you, merci but no chance to get it!
My web:
www.anim3d.de.tl
