Acrobat and Houdini...How?
7883 6 0-
- soundview00
- 7 posts
I have downloaded Adobe Acrobat 506 to use with houdini 6 apprentise, but when I try to open a houdini document within Houdini…I can't. How can I configure Houdini to use Adobe Acrobat with houdini? I am using RedHat 9.0 and have little Linux experience, so any simple ways to do it would be GREATLY appreciated. Thanks all.
- goldfarb
- 3465 posts
- soundview00
- 7 posts
- soundview00
- 7 posts
- wolfwood
- 4360 posts
- JColdrick
- 4140 posts
I've noticed you're a Linux newbie - welcome!
When you install acrobat by default, I think it sticks in in
/usr/local/Acrobat5
(depending on version). What you can do quickly, rather than adding a specific location to your path for one measly app, is to setup a link in a common path local - like /usr/local/bin. As root:
cd /usr/local/bin
ln -s /usr/local/Acrobat5/bin/acroread .
(note the period - it's critical). Then, start a new shell and launch Houdini - it should be in your path. Obviously double-check that the location I've suggested is accurate.
J.C.
When you install acrobat by default, I think it sticks in in/usr/local/Acrobat5
cd /usr/local/bin
J.C.
John Coldrick
- soundview00
- 7 posts
