Very strange, but happened yestoday.
Almost couldn't run.
There were no changes about Double Buffering, Draw Lines Smoothly,
reserve for undo system, and other applications were runnig at the same
time with Houdini.
I opened a .hip file random, which was about 200KB,
with no operations, saved, and the file became about 20M.
Perhaps because of this.
Any suggestion?
Thank you.
Why Houdini became slowly.
3824 2 0-
- Xiangbiao
- 27 posts
- stevenong
- 1634 posts
May I know which version are you using? 5.5 or 6.0?
Also, are you using Linux or Windows? NT, 2000 or XP?
Is the hip file you loaded downloaded from the web? If it is, may I know the link to the file?
Last but not least, did you do anything with the hip file? For example, adding a new object or creating new operations?
Cheers!
steven
Cheers!
steven
- Xiangbiao
- 27 posts
Thank you.
I'm using 5.5 on xp.
The .hip file are created by myself.
Even if I createed a new one, without any operations, save it,
the Untitle file would became about 20M.
Sure, I did many operations to the file.
I didn't notice which operation after it the speed became slowly.
CPU: Celeron 900 MHz.
RAM: 128M.
Video card: Sis 630, 8M, compositive within mainboard.
Thank you.
RAM: 128M.
Thank you.
