Fist off: Hi to eveyone. I am just starting to fiddle around with Houdini and although I must say this package has a rather steep learning curve I already love it.
While experimenting around I ran into this problem: I have a couple of points, say through just a grid and a scatter SOP. Now what I want to do is delete every point, which is closer than X to its nearest neighbour.
Could any of you pros point me into a possible direction of doing this? I'd guess the easiest way would be through a VOP SOP and some pointcloud operations. I did give it a try already, but it *is* a bit weired to wrap my head around for starters
scatter sop allows you to store the distance to N neighbours in each point. You can use a deleteSOP to delete the points below the treshold. hope this helps
