RBD Fractured Object doesn't work
   4989   1   1
Hi!
My RBD Fractured Object tool doesn't work. When I use a simple model like a box, sphere or tube and I hit the RBD Fractured Object button, the AutoDOPNetwork and the FracturedObject node within the SOP network get created, but the object isn't actually fractured at all. Am I doing something wrong?
Kind regards,
Phong
Hi, The RBD Fractured Object doesn't fracture your object. You have to pre-fracture your objects yourself before you can use RBD Fractured Object. You might want to looking into the new shatter tools instead to help you build fractured geometry.
RBD Fractured Objects simply making all your fractured objects as separate pieces of geometry and glue them together until enough impact force is applied on them to make them break up.
HTH.
