Interesting problem
   4392   2   0
Ok the Render problems go this time in Windows. The URL will explane the problem complete with pictures to clarify. Very Weird Nodes are set to render yet only some of them do. When I test the group merge where a few from a group aren't showing they all render. That probably does not make much sense but the Link explains it well.
http://odforce.net/forum/index.php?s=9f103e3d9d1676ca2fb150b225dcd157&act=ST&f=22&t=941&st=20 [odforce.net]
Nate Nesler
P.S. Thanks In Advanced! 8)
Can Merge only take 16 inputs? If so how do you get around this?
Nate Nesler 8)
It was my shader! It was transparent in some areas and when the geometry got higher the shader became more reflective. Very Odd! Test Solution is on the first link posted.
Nate Nesler
